What are these switches
bandersen55
Vessel Info: 2002 Carver 506
Has thanked: 8 times
Postby bandersen55 » June 9th, 2021, 6:01 pm
I have 4 switches on my dashboard. Two of them I can read and two are wore to the point they are unreadable. Does anyone know what they do? Also, do you know where I can order new ones with the correct labels?
2002 Carver 506
Lake Powell
Been thanked: 1043 times
Re: What are these switches
Postby km1125 » June 9th, 2021, 8:42 pm
Sometimes I try shining different colored lights at an angle on the surface and you can read some faded labels better. If you have a laser pointer, try that too.
vineyardgray
Has thanked: 125 times
Been thanked: 32 times
Postby vineyardgray » June 10th, 2021, 10:39 am
Here are my guesses on the wording:
Switch 1 - no idea
Switch 2 Cruise1, OFF, Cruise 2
Switch 3 no idea (maybe Fast?), Slow, Idle
Switch 4 + RPM -
What do they do? Total mystery
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
Netherlands
Phrancus
Has thanked: 16 times
Been thanked: 132 times
Postby Phrancus » June 10th, 2021, 10:41 am
What happens when you push them.... :-D :-D ;-)
Carpediem
Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
Has thanked: 2 times
Been thanked: 25 times
Postby Carpediem » June 10th, 2021, 10:56 am
You can buy replacement rocker actuators at Flounder Pounder Marine.
https://www.fpmarine.com/Switch-Actuator-s/387.htm
There are hundreds of choices, I would call them, they are very helpful. They are suppliers for OEM Searay parts and those are the same switches on Sea Rays of that vintage.
Carpe Diem
Try to only boat where ducks don't walk
Postby km1125 » June 10th, 2021, 11:13 am
Ran across this today. Looks like your panel extends to the right further, so you couldn't actually use these, but the labelling/use would be the same I would think. There are a few companies out there that will make custom-engraved covers for those switches too, so you could even change the descriptions a bit if you wanted to.
https://www.searay-parts.com/Cummins-En ... ummins.htm
bandersen55
Postby bandersen55 » June 11th, 2021, 12:15 pm
Thank you all for the information. My guess is Engine Sync, Cruise 1/2, Slow Idle, and RPM adjust. I'll be on my boat in a couple of weeks and try it out.
2002 Carver 506
Lake Powell
Netherlands
Phrancus
Postby Phrancus » June 11th, 2021, 1:49 pm
Sounds like features I'd like to have. Mine is older than that I suppose. I have a dial that shows the balance of engines RPM. nothing more. And only downstairs in the cabin.
I would have expected a bit smarter material such as a physical engine synchroniser: shove the throttle handles and both engines produce an equal thrust. Apparently that was not relevant at the time without engine electronics. So I keep fiddling with the throttle handles, listen to hear the interference of the engine sounds and look at the RPM dials to find a good balance.
After all long overdue maintenance jobs are done I might have a go at it with some electronics and servo's.
Although, usually by that time I've moved on to a more modern vessel that has that on board or got used to that fiddling and not care so much about improving old stuff any more :blush:
Users browsing this forum: No registered users and 60 guests
