What are these switches
- bandersen55
- Vessel Info: 2002 Carver 506
- Has thanked: 8 times
Lake Powell
- Been thanked: 1043 times
Re: What are these switches
- vineyardgray
- Captain
- Has thanked: 125 times
- Been thanked: 32 times
- Contact:
Switch 1 - no idea
Switch 2 Cruise1, OFF, Cruise 2
Switch 3 no idea (maybe Fast?), Slow, Idle
Switch 4 + RPM -
What do they do? Total mystery
1988 Carver
3867 Santego
PCYC
- Phrancus
- Has thanked: 16 times
- Been thanked: 132 times
- Contact:
- Carpediem
- Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
- Has thanked: 2 times
- Been thanked: 25 times
https://www.fpmarine.com/Switch-Actuator-s/387.htm
There are hundreds of choices, I would call them, they are very helpful. They are suppliers for OEM Searay parts and those are the same switches on Sea Rays of that vintage.
Carpe Diem
https://www.searay-parts.com/Cummins-En ... ummins.htm
- bandersen55
Lake Powell
- Phrancus
- Contact:
I would have expected a bit smarter material such as a physical engine synchroniser: shove the throttle handles and both engines produce an equal thrust. Apparently that was not relevant at the time without engine electronics. So I keep fiddling with the throttle handles, listen to hear the interference of the engine sounds and look at the RPM dials to find a good balance.
After all long overdue maintenance jobs are done I might have a go at it with some electronics and servo's.
Although, usually by that time I've moved on to a more modern vessel that has that on board or got used to that fiddling and not care so much about improving old stuff any more
Users browsing this forum: No registered users and 60 guests
