Odd Charging While Under Way
- Has thanked: 270 times
- Been thanked: 1159 times
Re: Odd Charging While Under Way
Checked the manual and everything I have from Carver but nada when it comes to schematics on how this is set up. No macerator on board and the vacuflush heads both work like a charm and never cycle on between flushes.
Regardless of the route I take, the old style diode isolator will be removed. These are the ones Carver installed. https://www.electrobat.com/en/articulo/ ... 60-amp.htm
I can see why they need 2 because their maximum input is 160a whereas we are dealing with a 135a alternator on each engine, these are the stock Volvo alternators by the way.
- Has thanked: 585 times
- Been thanked: 1231 times
Midnightsun wrote:Source of the post Regardless of the route I take, the old style diode isolator will be removed. These are the ones Carver installed. https://www.electrobat.com/en/articulo/ ... 60-amp.htm
You know, considering , you may have found your switching source, interesting question would be to see how they would handle such a large draw coming from two separate sources with each one being regulated. When you changed to one source charger all calmed down.
The alternators were always charging through the isolators, all I did was start the genny to add shore power charging. This somehow allowed thing to charge properly. After the shore power charging "kickstart", things got back to normal. Almost as if the alternators were flipping on and off which I seriously doubt. The isolators are really only diodes or electrical check valves if you prefer. Not sure if over demand on a diode does anything weird or if it just burns them out. Mystery for sure.
FYI, I have no way of combining batteries through a 1/2/all switch so nothing funky/forgotten that could be the cause. This is factory from Carver. All batteries do have an on/off switch though.
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
This was happening to my boat after I had pushed my house battery down to those low levels. I couldn't figure out why my alternators were not charging the house battery but charging everything else. I was finally able to figure out the problem. I am not sure if you have resolved your issue.
In my boat, under my step where the battery switch is for the house battery there are two high amp breakers. I noticed one of them had tripped. Turns out it is a breaker between my alternators and the house battery. I turned the breaker on and they started to charge again, but then the breaker tripped a short time later.
This is what was happening. When my battery was discharged to a low point after being anchored, and I was running my engines, it would appear that the battery was drawing to much from the alternators and was tripping the breaker.
Now that I have my solar and I am anchored out, like I just was for 8 days, the batteries are not getting discharged enough and I am not having this problem anymore. This could be your issue.
I know that this this sounds like a quick solution, but see if you have a breaker between your alternators and your house batteries. Worked for me.
Hope this helps you.
Greg
Users browsing this forum: No registered users and 50 guests
