466 MY swim platform
ems05#05
Vessel Info: 2004 466 my
twin volvo tamd75
Has thanked: 5 times
Been thanked: 4 times
Post by ems05#05 »
looking to mount a dingy caddy on my platform , could someone confirm if there are two metal plates built into the platform?
Schoony
Vessel Info: 2001 Carver 466 Motor Yacht
Been thanked: 10 times
Re: 466 MY swim platform
Post by Schoony »
You can crawl inside your swim platform from the aft tall closet by the bathroom door, there is a access panel in that closet that gives full access to the inside of your swim platform, i have a davit system on my 466 which they installed steel backing plates inside the swim platform. not a hard install to do.
ems05#05
twin volvo tamd75
Post by ems05#05 »
thanks for the info, did you thru bolt all way or screw it down . the lift comes with toggle bolts but i would rather not go all the way thru
Schoony
Post by Schoony »
Yes, You have to go tru for it to hold properly, send me your email and i can send you some pics of the system i have on my 466.
ems05#05
twin volvo tamd75
Post by ems05#05 »
cres05ems@gmail.com
thanks for the help
Eric
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Post by Tireless »
I have a different boat, however, I had two aluminum supports running front to back, in the core of my swim platform between the upper and lower layers of fibre glass. I was not able to see the aluminum stripes from underneath. It is aluminum, so you can drill trough it If you hit it.
I was advised by Carver that they were there and I did drill through one doing my install.
Greg
ems05#05
twin volvo tamd75
Post by ems05#05 »
I was told there were two plates built into the platform, i guess i will find out soon enough
Been thanked: 1114 times
ems05#05 wrote:Qr Bbpost I was told there were two plates built into the platform, i guess i will find out soon enough
Tireless wrote:I have a different boat, however, I had two aluminum supports running front to back, in the core of my swim platform between the upper and lower layers of fibre glass. I was not able to see the aluminum stripes from underneath. It is aluminum, so you can drill trough it If you hit it. ....
That's the kind of information that would be GOLDEN to have in the owner's manual or other documentation provided with the vessel!! :-D
Tbw5959
Vessel Info: 2004 466 M/V Salt and Light
Volvo TAMD75's & Kohler 20kW generator
Has thanked: 39 times
Post by Tbw5959 »
Eric, Would you please keep us posted on this? We've just recently acquired a 466 also -- and thinking along the same lines.
Thank You!
Ted
ems05#05
twin volvo tamd75
Post by ems05#05 »
There is a metal plate extending from the edge of the platform almost to the deck box
