1977 Carver 2896
Jimj
Vessel Info: 1987 Carver 2896
1977 Carver 2896
Post by Jimj »
Hello from Vancouver Washington. I’m strongly considering buying a 1977 2896. It’s been moored covered and seems solid. Im concerned about potential balsa core issues. It has original twin mercury 351 Windsor’s with Velvet V Drives with 700 hours. Meticulous maintenance records. The engines seem to run very well with one drive needing inspection. Any thoughts on this boat and the propulsion system? Looking for a local hull surveyor. Jim
Re: 1977 Carver 2896
Welcome aboard Jim
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Post by buster53 »
Good luck going forward on this.
You mentioned getting a hull surveyor. Don’t stop there. You need a full pre-purchase survey that will check the hull, deck, engines and all systems and most likely will take the boat on a sea trial.
Pretty sure your insurance company will insist on it.
Jimj
Post by Jimj »
I will get a full survey. Hoping someone from the Portland Oregon area can recommend a good surveyor. I’m interested in hearing from folks who have owned this boat.
Been thanked: 1114 times
Welcome aboard Jim!
Been thanked: 492 times
Post by waybomb »
Welcome aboard!
