Caulking around windows
rfverdery
Vessel Info: 2001 Carver 466. Twin TAMD 74 P 480 Volvo’s.
Has thanked: 26 times
Been thanked: 2 times
Post by rfverdery »
Recently purchased a 466. The caulking around all the front windshield is cracked and weathered. Anyone know the best product to use and the best way to remove the old. Thanks!
wkeith
Vessel Info: 2004 Carver 466 Aft Cabin MY
Has thanked: 8 times
Been thanked: 14 times
Re: Caulking around windows
Post by wkeith »
I had the same problem with the molding in the windshield bottom corners. The boat yard cut out the rotted molding and filled it with black sealer. Has worked fine.
rfverdery
Post by rfverdery »
Thank you, I need to replace all of it not sure how the black would look, do you know the name of the product?
wkeith
Post by wkeith »
3M Marine Adhesive Sealant 5200 (06504) Permanent Bonding and Sealing for Boats and RVs Above and Below the Waterline Waterproof Repair, Black.
Personally I wouldn't use 5200, maybe 4200 or another product but what ever you use, get a product that is UV rated.
Post by Midnightsun »
I would use Sikaflex 291. 5200 is like a permanent bond/glue
rfverdery
Post by rfverdery »
Thank you for the responses I now have somewhere to start. Just finished removing, boiling and replacing the raw water system on both engines. Windows are next.
