Caulking around windows
- rfverdery
- Vessel Info: 2001 Carver 466. Twin TAMD 74 P 480 Volvo’s.
- Has thanked: 26 times
- Been thanked: 2 times
Recently purchased a 466. The caulking around all the front windshield is cracked and weathered. Anyone know the best product to use and the best way to remove the old. Thanks!
- wkeith
- Vessel Info: 2004 Carver 466 Aft Cabin MY
- Has thanked: 8 times
- Been thanked: 14 times
Re: Caulking around windows
I had the same problem with the molding in the windshield bottom corners. The boat yard cut out the rotted molding and filled it with black sealer. Has worked fine.
- rfverdery
Thank you, I need to replace all of it not sure how the black would look, do you know the name of the product?
- wkeith
3M Marine Adhesive Sealant 5200 (06504) Permanent Bonding and Sealing for Boats and RVs Above and Below the Waterline Waterproof Repair, Black.
Personally I wouldn't use 5200, maybe 4200 or another product but what ever you use, get a product that is UV rated.
- rfverdery
Thank you for the responses I now have somewhere to start. Just finished removing, boiling and replacing the raw water system on both engines. Windows are next.
