Remove and replace old reading fixture
Re: Remove and replace old reading fixture
Perfect. Turn your breaker off at the panel that controls that circuit and wire the fixtures as mentioned above temporarily. Keep the wires separated so the yellows and blacks don't touch each other, tape them if you have to. Then turn your breaker back on and try them. If they work properly, turn the breaker back off, wire them permanently, and fasten them to the wall. Then send us a pic!
BoatGirl
Vessel Info: 2004 Carver Mariner 420
Has thanked: 13 times
Been thanked: 3 times
Post by BoatGirl »
Success!! I did have help from my boat neighbor.
Awesome, looks great BG :down:
Post the info on where you got them in case another member is thinking of doing the same thing.
Coldcruisin
Been thanked: 7 times
Post by Coldcruisin »
I suspect its a straight forward hot 12v feed and as Viper suggested, left side feeds the right. Each fixture having its own switch will not effect the other. Dont be afraid to wire one in temporarily as Viper said. The nice thing about 12v....it does not sting like 110v. :-D
Oops... glad you got it sorted.
BoatGirl
Post by BoatGirl »
Apex lighting :-)
