Remove and replace old reading fixture
Re: Remove and replace old reading fixture
Perfect. Turn your breaker off at the panel that controls that circuit and wire the fixtures as mentioned above temporarily. Keep the wires separated so the yellows and blacks don't touch each other, tape them if you have to. Then turn your breaker back on and try them. If they work properly, turn the breaker back off, wire them permanently, and fasten them to the wall. Then send us a pic!
- BoatGirl
- Vessel Info: 2004 Carver Mariner 420
- Has thanked: 13 times
- Been thanked: 3 times
Success!! I did have help from my boat neighbor.
Awesome, looks great BG
Post the info on where you got them in case another member is thinking of doing the same thing.
- Coldcruisin
- Been thanked: 7 times
I suspect its a straight forward hot 12v feed and as Viper suggested, left side feeds the right. Each fixture having its own switch will not effect the other. Dont be afraid to wire one in temporarily as Viper said. The nice thing about 12v....it does not sting like 110v.
Oops... glad you got it sorted.
