Digital Speed Log Impeller Replacement
Has thanked: 455 times
Been thanked: 1671 times
Postby Viper » January 19th, 2016, 8:38 pm
waybomb wrote:
> Everybody should cycle your seacocks often; you never know when you will need them,
> and when you do, you don;t want them stuck.
Amen to that
Topic author
wetfolly
Vessel Info: 1987 Carver Riviera
Postby wetfolly » January 23rd, 2016, 2:41 pm
What's a seacock and how many do I have on my Riviera?
Postby Viper » January 23rd, 2016, 9:35 pm
A seacock is a valve installed at every through hull water intake below the water line. Typically there would be one at each engine raw water intake, the generator intake, air conditioning water pump intake, raw water washdown intake if applicable, intake for the head if it's a raw water unit, etc. If the vessel is equipped with overboard discharge for black water, then there would be a seacock for that as well. Some OEMs install seacocks on all through hull fittings above the water line as well. I don't recall any Carvers with that though. Mostly sail boats and ocean going vessel designs as a safety feature for rough seas.
https://www.google.ca/search?q=seacock&biw=1132&bih=612&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiHqI2qtMHKAhWqw4MKHUiFBkoQsAQIKQ#imgrc=Vg612n7EXOjA-M%3A
Users browsing this forum: No registered users and 43 guests
