Relay switch
- MarkMaunder
- Vessel Info: 1990 Carver 27 Santego
Volvo Penta 740
Duo-prop - Location: Fifty Point Marina - Grimsby ON Canada
- Has thanked: 5 times
Relay switch
- Been thanked: 1043 times
Re: Relay switch
You can probably use a bunch of similar relays in it's place, if you can't find an exact replacement. There are more numbers on the side that show the contacts, but I can't read them from that pic. The big difference in a replacement might mean the mounting method. Looks like the mounting tab is broken off yours.
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 15 times
- Been thanked: 36 times
Re: Relay switch
- Has thanked: 455 times
- Been thanked: 1671 times
Re: Relay switch
- MarkMaunder
Volvo Penta 740
Re: Relay switch
km1125 wrote:Source of the post The "332014 150" would be the BOSCH part number. It's a 12V relay capable of 30 Amps.
The numbers on the side are just a schematic I believe. (pic attached)
- MarkMaunder
Volvo Penta 740
Re: Relay switch
Viper wrote:Source of the post Those are common relays but you'll need to check if it's a 4 or 5 pin and make sure you get a 30 amp one. Post the engine serial number
Engine - 1 engine, 1990, VOLVO, , 4100112889, 300CV 740 DP
- MarkMaunder
Volvo Penta 740
Re: Relay switch
plittle2005 wrote:Source of the post Also check the key switch itself, they can fail.
Good thought, but that was replaced last year. Although I am going to get another as a backup and to eliminate that possibility if it's not the relay.
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Relay switch
- MarkMaunder
Volvo Penta 740
Re: Relay switch
- MarkMaunder
Volvo Penta 740
Re: Relay switch
bud37 wrote:Source of the post Have you checked power to the relay when it fails ?
No I haven't. I will next time it fails though. Thank you!
Users browsing this forum: No registered users and 85 guests
