Cummins 450 diamond series
Bakoboat
Vessel Info: 456 carver 2000
Post by Bakoboat »
Does anyone know if the cummins 450 diesels will continue to run if battery power is cut off.
As I sort through some battery issues I'm wondering what would happen if I lost dc power while engines are running. I know diesels are unlike gas engines, however would loss of power shut off fuel supply automatically or something else that would kill the engines?
Appreciate assistance with this.
Re: Cummins 450 diamond series
Would have to check but I suspect that vintage would have have some sort of electronic control system. If that's the case, power is needed for sure.
Sgodfrey
Vessel Info: Carver 450 Voyager
Been thanked: 9 times
Post by Sgodfrey »
If you have 6cta 450 diamond they will run without dc power - you will need to actuate the fuel shutoff solenoid to stop the flow of fuel to shut them down.
If however you have electric controls - that were used in the early 2000 +/- they require power
Bakoboat
Post by Bakoboat »
Thanks for the info. The boat is a 2000 model built in 99.
How would I know if I have electric controls?
Thanks again,
Mb
