396 MY Dock Side Access Door Hinges
- Vessel Info: 2003 Carver 396
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 120 times
- Been thanked: 120 times
Re: 396 MY Dock Side Access Door Hinges
Anyway, as I was doing this it revealed yet another issue: several of the screws were stripped out and not really holding anything.
Once the hinges were off I took a soft mallet and a vice (with padded jaws) and got the hinges flat again and working properly.
Next I ordered the following on Amazon and retapped the stripped holes and used the new threaded inserts:
https://www.amazon.com/dp/B0092QVJUS?ref=ppx_pop_mob_ap_share
Finally, I put it all back together using butyl tape for all the screw holes and everything works great!!
I realize this didn't answer your question of where to find new hinges, but maybe this might be a solution if yours are not too damaged.
Good luck!
Kyle
2002 Carver 396
- Cooler
- Has thanked: 68 times
- Been thanked: 399 times
- KyleR
2002 Carver 396
Kyle
2002 Carver 396
- KyleR
2002 Carver 396
An internet search didn't reveal much for that part number so I called Perko to see if they they still made them. Unfortunately they are a discontinued line but they did have four sets still in inventory. They revised the part number, which is now 1002012DP.
Hope this helps someone!
Kyle
2002 Carver 396
Users browsing this forum: Google Adsense [Bot] and 75 guests
