396 MY Dock Side Access Door Hinges
Ojgami
Vessel Info: 2003 Carver 396
Postby Ojgami » January 1st, 2024, 5:50 pm
Hi everyone! I’m a new Carver 396 owner and am trying to make a few repairs before spring. My starboard side dock access door is difficult to open and close because the hinges are bent and cracking. I can’t seem to find replacements anywhere so far. They are three-hole 4” x 3” hinges. I’ve attached a pic. Any help on sourcing a replacement would be much appreciated!
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 120 times
Been thanked: 120 times
Re: 396 MY Dock Side Access Door Hinges
Postby KyleR » January 2nd, 2024, 7:18 pm
I had a similar situation. What I ended up doing was first removing the door and hinges. It's a good idea to have someone help with the door so it doesn't end up in the water!! I didn't have anyone to help and it got a little sketchy at times!!
Anyway, as I was doing this it revealed yet another issue: several of the screws were stripped out and not really holding anything. :banghead:
Once the hinges were off I took a soft mallet and a vice (with padded jaws) and got the hinges flat again and working properly.
Next I ordered the following on Amazon and retapped the stripped holes and used the new threaded inserts:
https://www.amazon.com/dp/B0092QVJUS?ref=ppx_pop_mob_ap_share
Finally, I put it all back together using butyl tape for all the screw holes and everything works great!!
I realize this didn't answer your question of where to find new hinges, but maybe this might be a solution if yours are not too damaged.
Good luck!
Kyle
MV Verity
2002 Carver 396
Ojgami
Postby Ojgami » January 2nd, 2024, 10:34 pm
Thanks Kyle, that’s starting to look like my only real option. I considered taking it off and hammering it out, but hadn’t thought about the other issues you mentioned. I found what sounds like the right replacement hinges at West Marine, but it’ll cost me $190 per hinge to find out if they’re right. I’m leaning towards your solution unless someone comes up with a better option.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 399 times
Postby Cooler » January 3rd, 2024, 12:48 pm
Have you tried greatlakesskipper.com ? Search Carver OEM parts and hinges. Good luck! 8-) er
Cooler By The Lake
Ojgami
Postby Ojgami » January 3rd, 2024, 11:26 pm
Thanks Cooler
KyleR
2002 Carver 396
Postby KyleR » October 9th, 2024, 8:18 am
Just wanted to see if you ever found replacement hinges for your door? Always good to have a source - just in case! Thanks!
Kyle
MV Verity
2002 Carver 396
KyleR
2002 Carver 396
Postby KyleR » February 15th, 2025, 9:36 am
As an follow-up, when removing my hinges to rebed the screws, I found a stamp on the back that said these were Perko No. 12 hinges. Since mine are a little worse for wear, I thought I might replace them while they're off.
An internet search didn't reveal much for that part number so I called Perko to see if they they still made them. Unfortunately they are a discontinued line but they did have four sets still in inventory. They revised the part number, which is now 1002012DP.
Hope this helps someone!
Kyle
MV Verity
2002 Carver 396
Users browsing this forum: No registered users and 75 guests
