New owner, new experience.
Grizz
Vessel Info: 1978 cutter voyager 3326 33.5 ft
Post by Grizz »
Hi I am thankful to stumble upon this site as I am a new owner of a 1978 voyager cutter 33.5 ft boat. I am looking for understanding of the following questions.
1. Manual says it has 2 200 gallon stansless steal tanks? Is that 100 x 2 for 200 total capacity or two two hundred tankes for a total of 400 g? How far can I travel an an easy go speed?
2. How many people fit on the boat when checked by coastguard?
3. Are there two piglet houses? How does this work?
Thanks in advance.
Been thanked: 1114 times
Re: New owner, new experience.
Not sure if this is the exact boat, but the PowerBoat Guidebook says it's 200 total:
Your best range would be below hull speed... probably 7kts or so and you might get 1.5 mpg, so ~250 miles max leaving a little fuel in the tank. But that also depends on how clean the bottom is and how well the engines and drivetrain are being maintained.
Not sure what you're talking about with "piglet houses"?
Been thanked: 492 times
Post by waybomb »
Welcome aboard!
No idea what a piglet house is either. Possibly spell check and the vessel has two helms? If that's what you are asking, you can operate the boat from either station. You don't need to switch over anything, either one works.
Welcome aboard
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 211 times
Post by pepmyster »
Welcome!!!!!!!!!!!
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 414 times
Post by Cooler »
Welcome to the neighborhood! Can't wait to hear what a piglet house is. Hope a previous owner was not smuggling pigs for any reason! 8-) er
Cooler By The Lake
Been thanked: 470 times
Post by RGrew176 »
Welcome Aboard.
