New owner, new experience.
Grizz
Vessel Info: 1978 cutter voyager 3326 33.5 ft
Postby Grizz » July 14th, 2024, 2:45 pm
Hi I am thankful to stumble upon this site as I am a new owner of a 1978 voyager cutter 33.5 ft boat. I am looking for understanding of the following questions.
1. Manual says it has 2 200 gallon stansless steal tanks? Is that 100 x 2 for 200 total capacity or two two hundred tankes for a total of 400 g? How far can I travel an an easy go speed?
2. How many people fit on the boat when checked by coastguard?
3. Are there two piglet houses? How does this work?
Thanks in advance.
Been thanked: 1031 times
Re: New owner, new experience.
Postby km1125 » July 14th, 2024, 3:57 pm
Not sure if this is the exact boat, but the PowerBoat Guidebook says it's 200 total:
Your best range would be below hull speed... probably 7kts or so and you might get 1.5 mpg, so ~250 miles max leaving a little fuel in the tank. But that also depends on how clean the bottom is and how well the engines and drivetrain are being maintained.
Not sure what you're talking about with "piglet houses"?
Has thanked: 53 times
Been thanked: 425 times
Postby waybomb » July 14th, 2024, 4:50 pm
Welcome aboard!
No idea what a piglet house is either. Possibly spell check and the vessel has two helms? If that's what you are asking, you can operate the boat from either station. You don't need to switch over anything, either one works.
Has thanked: 455 times
Been thanked: 1668 times
Postby Viper » July 14th, 2024, 9:16 pm
Welcome aboard
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 474 times
Been thanked: 201 times
Postby pepmyster » July 15th, 2024, 6:00 am
Welcome!!!!!!!!!!!
Been thanked: 390 times
Postby Cooler » July 15th, 2024, 10:58 am
Welcome to the neighborhood! Can't wait to hear what a piglet house is. Hope a previous owner was not smuggling pigs for any reason! 8-) er
Vessel Info: 2022 Stingray 182 SC
Been thanked: 467 times
Postby RGrew176 » July 16th, 2024, 1:22 am
Welcome Aboard.
