I went down to the boat today to find a pretty major leak coming from the toilet on our 325. Any standing water had drained down the shower drain, but the bath mat in there was completely saturated and there was quite a lot of water on the floor in the head.
I had noticed recently that the level in the black water tank seemed to be increasing while the boat was at the dock and the toilet wasn’t being used, but I thought maybe it was just due to the boat rocking back and forth or something.
As far as I can tell, the water pump module on the toilet is broken, or there is some sort of valve in the pump that is stuck open, because water was freely flowing up the flush hose and into the bowl.
The leak that made is way unto the head floor was due to the water coming up the flush hose and backing up into the line from the deodorant reservoir, which eventually overflowed and leaked out onto the floor.
In the process of checking all this out, I also found out our shower sump stopped working (going to post another thread on that)
Here’s a picture of the toilet (Crown model, original from 1996). Unfortunately I don’t have the manual, but I think it’s best I just replace the whole thing anyway.
If you have any suggestions for a simple fix, I’m all ears.
Here is where I need help. In choosing a new toilet, there are two types: one which is designed to be connected to a pressurized fresh water system, and the other which has a water pump to draw water from a raw water intake. When I went into the engine compartment to try to turn off the water, I was expecting just a raw water seacock. The owners manual said that all toilets, regardless of model, were fed by a raw seawater intake. However, when I dug in, that’s not what I found. It seems like the PO plumbed the toilet intake to the fresh water system on the boat, but did it upstream of the water pump, so it is essentially fresh water, but unpressurized. Am I seeing this correctly? Yellow arrows are pointing to the toilet intake hose.
If I’m correct and that is how it is plumbed, then I think I’ll need to use the style of toilet that has a pump and is designed for a raw water intake. It was very obvious that the toilet is not connected to the pressurized water system based on the slow drip of a leak, and because turning the water pump off and draining the water in the lines going to the sinks did not change the flow coming through the toilet flush line at all. I did turn off the red valve upstream of the water pump and toilet intake and that stopped the flow at the toilet.
Thanks so much for any guidance you can provide.
