Postby bud37 » January 2nd, 2025, 10:17 pm
Geez those critters can do a lot of damage.......Maybe you have.......but before you put it back together, may be a good idea considering to check all your exhaust hoses on the inside back to the engines, the rodent could have been in there on the other side as well. Sometimes they will chew part way and it won't show on the outside till it burns thru while underway or just a small hole and Carbon Monoxide gases leak into the boat. I had to put screens on all our boats.
Could you post a pic then someone may recognize the style you have.
FWIW.....The above is just my opinion.....
