1973 Monterey 2585 bringing her back to life
lrfickau
Vessel Info: 1973 Monterey 2585 OMC 225hp single IO
"SEA STAR"
Been thanked: 5 times
Re: 1973 Monterey 2585 bringing her back to life
Post by lrfickau »
Here is what I'm going to do first.
Pull the plugs
Fog the cylinders
Turn engine over by hand
refog cylinders
turn engine over with starter
check spark
reinstall plugs
remove fuel line to carb
put a line from carb into a 5gal jug with fresh gas w/lead additive.
Hook up muffs to water hose
Then try to fire her up
after that check compression.
if all goes well I fallow Waybomb list and prepair for a shakedown cruise in sping.
Yes I will rewinterizer it before winter.
Been thanked: 492 times
Post by waybomb »
Engines in my boat were froze solid from sitting still all those years.
I attempted to break them lose using the crank bolt but that wasn't working.
That's why I took the dampener off, so I could use a proper crank hub socket to rock the crank back and forth. You won't do that with the bolt of the Rings are stuck at all.
Btw, the engines only had about 250 hours on them.
lrfickau
"SEA STAR"
Post by lrfickau »
Today I brought the girl home. remove plugs, fogged the cylinders, turned engine over by hand several times, turn over with the starter, we have spark at the plugs. Next step is to run the fuel line to a 5gal jug of fuel and see if it starts. the fresh water pick up I would not be able to use the ear muffs. So could I use a cut off 55 gal drum and lower the stern drive into the water along with a garden hose running to keep the drum full and then start the engine. by the way there in no fresh water pump with a rubber impeller. I looks like it uses a conventional engine water pump.
Post by waybomb »
Just remember that 55 gallon drum will get hot quickly.
Can you adapt a garden hose to the hose leading from the sea cock?
Post by tomschauer »
The raw water pump is in the outdrive. It supplies water to the conventional water pump on the engine. The engine pump will not pull water from the barrel. If you start it and it doesnt move water shut it down asap. You will crack your manifolds before it registers an over heat with no water in the engine.
Post by waybomb »
So it sucks the water up through the outdrive and then out the exhaust?
Disregard my previous comment then about getting hot
It will get empty very quickly.
lrfickau
"SEA STAR"
Post by lrfickau »
Brought the girl home today. pulled the spark plugs, fogged the cylinders, turned the engine over by hand, cranked it over with the starter, had spark at the plugs,reinstalled spark plugs. Next it to put the fuel line into a 5gal jug of fuel and try to start it. There is no fresh water pump with a rubber impeller. looks like it uses a conventional GM water pump. The water muffs will not work on this drive. What do you think about using a cut off 55gal drum of water with the garden hose running into it and lowering the stern into the drum of water?
lrfickau
"SEA STAR"
Post by lrfickau »
Yes the raw water pump pulls the water through the out drive and into the engine water pump if raw water cooled.
Into a heat exchanger if fresh water cooled. Then out the exhaust manifolds and back down the drive exiting through the prop.
If the pump has any vanes on it after sitting for 16 years they will all be gone after a couple revolutionS of the engine.
Then no cooling water to the engine.
Also this drive should have a port to connect a garden hose to just under the water pump about a foot from the bootie if I remember correctly
