nolacarver
Posts: 19 Joined: October 6th, 2013, 6:49 pm
Vessel Info: 1979 33' carver New Orleans, LA
Post
by nolacarver » March 22nd, 2015, 6:26 pm
My tachometer and volt meter is consistently chattering in sync very erratically. any suggestions of a possible culprit ?
Thanks for any help!
Posts: 2745 Joined: February 5th, 2013, 9:24 pm
Vessel Info: 1995 Boston Whaler Rage15 1987 3697 Carver Mariner 1988 Cougar 46 Kevlar Vee offshore 1969 15' Glasspar / 1967 Johnson Electromatic 85
Has thanked: 69 times
Been thanked: 492 times
Post
by waybomb » March 22nd, 2015, 8:16 pm
One of the diodes bad in the alternator? That will cause pulses.
Thanks Fred 1969 Glaspar Avalon /1967 Johnson Electromatic 85 1987 Carver Mariner 1988 Cougar Kevlar 46' with triple blown 572 ci 1995 Boston Whaler Rage Past - 1988 2807, 1989 4207 Aft
nolacarver
Post
by nolacarver » March 23rd, 2015, 10:49 am
It is a new alternator but I guess that explains why the battery on that engine went dead after cruising. The amp meter is at 13 amps while running and chattering.is it possible to not charge battery even though it shows 13 amps?
Post
by waybomb » March 23rd, 2015, 11:36 am
If your shop does not have an alternator tester pull it out and bring it to a place like autozone. They have a rig that can fully test the alternator.
