Fuse box location
Topic author
Brad-87-mariner
Vessel Info: 1987 Carver Mariner, current port, lake lewisville Texas
Fuse box location
Postby Brad-87-mariner » September 8th, 2015, 2:02 pm
I have a 36' carver mariner vintage '87. I have a very simple question, My nav lights won't work, but I have power to the entire instrument panel. I would like to check the fuse's, but need to know where to look? do I need to remove the instrument panel to access the fuses?
Ramsport47
Been thanked: 57 times
Re: Fuse box location
Postby Ramsport47 » September 8th, 2015, 5:55 pm
Carver typically doesn't use fuse boxes...only circuit breakers on the "man panel" in the cabin. There should be one labelled for each item they are for...pretty good system historically
Kenny
T-Merc 350 Mag MPI (300hp)
Has thanked: 53 times
Been thanked: 426 times
Postby waybomb » September 8th, 2015, 9:31 pm
Check for power at the light socket itself wit the bulbs out.
I had to scuff all of mine in her restoration, the corrosion was not allowing flow of current to the bulbs.
But before I had power at the sockets, I had to actuate the switch many times to get the contacts to contact.
Users browsing this forum: No registered users and 126 guests
