I would like to ask for someones help. My wife purchased a 1976 Carver 33' Mariner with twin 351W engines. Does anyone have or could point me in the right direction for manuals, specs and parts.
My main concerns right know are getting the engines started and checking the electrical and water lines. This way I can get some idea of the costs to restore. Any help would be great. Also it has a 6.5 KW Onan generator. I have the manuals, but I cannot find a picture that shoes the mounting bracket for the small sea water pump that goes on the front. Most pictures show and L-brkt on the left, but this has to go on the right under the water manifold. No other place to fit it. By the way, it can be a beautiful boat again with the right manuals to restore properly.
New Member (asking for help, Please)
- Ozarkkid
- Vessel Info: 1979 Carver 33 Mariner with twin 351W engines. Wanting to restore
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 4 times
Re: New Member (asking for help, Please)
Morn,
Good luck with the restore. I have a 1977 but it has twin Chevy 350's, and it honestly don't know where the pump is either. I have done a lot but the engines were pretty low maintenance. My boat wasn't started for 5 years, I pumped a few gallons of water for the gas tank, started then engines and was on my way. Definitely had to work through a few fuel problems but for the most part, they were small.
Thanks,
Steve
Steve
- Ozarkkid
Thank You for responding.
Well I have made some movement with the boat. the Bad news is one of the engines is gone. Compression and leak test confirm. The other which I have since found out is a replacement engine, has good compression. So I will start working on getting that engine started. I found a remanufactured long block for $2,500.
The good news is I found a marine dealer here that will sand and paint the bottom for $2,100. plus blisters. I got the Ice Box, Stove and my wife helped and we got the pump and A/c working. I also found a very nice gentleman that designs electrical systems for larger boats to work with me correcting my mess. So things look good.
The last bad thing is we found out that the person we purchased it from was given the boat from a marina that was applying for abandoned status and went out of business. Coast Guard and State are making me jump through hoops to track the boat from the last legal sale. All work in progress.
- Solana
- Vessel Info: 38' Carver Santego - Complete refit 2016/2017
- Has thanked: 4 times
- Contact:
Here try this link from carver yachts. I went to their "service" tab on top then put in your boats info.
http://carveryachts.com/service/brochures-spec-sheets
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
For the engine manual, you will probably need to get a hold of the engine marinizer, who, judging by the age and auto block, is either Pleasurecraft or Waukesha. The latter of which is not longer around, so you may have to visit a library.
Kenny
T-Merc 350 Mag MPI (300hp)
