Shore Power Loss
- Gerald
- Vessel Info: 87 Montego 27.5 Foot, Mercruiser Engine V8
Marking on boat says dual cabin, I dont know what that means - Location: Detroit Michigan
- Has thanked: 2 times
Shore Power Loss
Does anyone have any suggestions?
87 Carver Montego
- Has thanked: 72 times
- Been thanked: 1055 times
Re: Shore Power Loss
What type of device do you have that switches from shore to genset... a dual breaker setup or a A/B (shore/genset) switch?
What is the "5 volt" system?
- Gerald
- Gerald
I cant locate the generator and battery charger in the engine room.
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
As others have said, start with the dock outlet, cordset, and work back from there. Check the shore power switch on the panel and make sure it's set to shore power, not off or gen. Check the main breaker and make sure it's not tripped. When you lose AC power, the battery charger won't work, and then the batteries go down over time. Is your boat in the water? If so, get this addressed NOW because the bilge pumps won't work either and your boat can sink at the slip.
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- Has thanked: 324 times
- Been thanked: 595 times
- Gerald
We checked for the battery chargers by pulling all wires from positive side of battery and checked for 12 V source to ground, nothing there.
We likely do no have battery charger. Does anyone know what it looks like and where it would be located???
- Has thanked: 458 times
- Been thanked: 1699 times
tomschauer wrote:Source of the post It is quite possible that your 87 montego does not have a generator or battery charger....
+1
Gerald wrote:Source of the post....We likely do no have battery charger. Does anyone know what it looks like and where it would be located???
They are typically in the engine compartment if they're a marine rated unit. Turn on all your 120v breakers, then listen for humming. If you have one and it's an original unit, it'll likely hum if it's working. Your vintage won't look fancy. Probably a metal blue or silver colour, may or may not have a meter on the front cover. Here are some pictures of various units:
https://www.google.ca/search?q=marine+battery+charger&rlz=1C1FLDB_enCA594&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiIp4XU-ZnUAhXp7IMKHZjLDq0Q_AUICygC&biw=1144&bih=633&dpr=1.25
https://www.google.ca/search?q=marine+battery+charger&rlz=1C1FLDB_enCA594&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiIp4XU-ZnUAhXp7IMKHZjLDq0Q_AUICygC&biw=1144&bih=633&dpr=1.25#tbm=isch&q=battery+selector+switch
