Looking for part on exhaust system
Been thanked: 414 times
Post by Cooler »
Hello All! I have a 1995 Crusader 350XL engine. The first fiberglas exhaust connector, with the built in back flow flapper, developed a crack and is leaking. It's about 5" long, and 3 3/4" wide. Anyone know where I can get the replacement part? The boat is a 330 Mariner. Thanks.
Re: Looking for part on exhaust system
Perhaps a Centek part....crusader/pleasurecraft marine parts.....have a fibreglass guy look at it, may be repairable.
SanJuanDreamer
Vessel Info: Still Searching
Been thanked: 21 times
Post by SanJuanDreamer »
As Bud37 mentioned....
On my Mariner, I have fiberglass mufflers, they have the back flow flappers.
They were leaking at the flapper axis.
I thought I would replace them but found they are ~$700ea...so...
I asked around and found out since they are fiberglass it can be repaired.
Post by Cooler »
Thx for the replies. The crack is not in the muffler, but the first connector immediately aft of the exhaust manifold. Fiberglas guy said he may be able to repair, but there is an overlap that concerns him. In the meantime, I found a stainless steel connector that may work, but it is an inch shorter. It is sold by Marysville Marine products. I will let you all know if that works for future issues. Thx again. Visit beautiful Door County in NE Wisconsin!
Post by Cooler »
Hello again. Follow up to the exhaust connector issue. The SS version available at MarysVille worked great. It is an inch shorter than the OM part, but there is enough length to get good connection to the exhaust hose. Part is $70. Happy cruising!
390Express
Has thanked: 141 times
Been thanked: 15 times
Post by 390Express »
Cooler wrote:Qr Bbpost aust hose. Part is $70. Happy cruising!
What did you end up doing with the fiberglass piece?
Post by Cooler »
I still have it. I may get it reglassed and use as a backup. Why do you ask?
