Is there really a difference between anchors?
amanphoto
Has thanked: 3 times
Been thanked: 12 times
Post by amanphoto »
I'm looking to upgrade my anchor from a delta plow to a newer designed anchor.
I was looking at the Rocna and the Mantus. They look the same, except that the Mantus is bolted together and the Rocna is welded. Is there really a difference?
Re: Is there really a difference between anchors?
Post by Midnightsun »
There is a huge difference however both of the ones you are looking at are among the best and compare well to each other. Delta plow is decent IMHO having owned a few of those but no competition for the Rocna or Mantus. A good upgrade in your case.
denpooch
Vessel Info: 2005 360 Mariner
Crusader 6.0 Captains Choice
Has thanked: 85 times
Been thanked: 89 times
Post by denpooch »
I upgraded my anchor last season and I researched 'ad infinitum' before I purchased. I decided to go with a Mantus 45 pounder. Grabs quick and holds great. The company is terrific. Also take a look at some of their other products several of which I believe are quite innovative.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 211 times
Post by pepmyster »
Owned a Rocna on my other boat because of a suggestion of a close friend, It was great ! Held as it should.
amanphoto
Post by amanphoto »
Midnightsun wrote:Qr Bbpost There is a huge difference however both of the ones you are looking at are among the best and compare well to each other.
What are the difference?
pepmyster
8.1 Volvo Penta
Fresh water boating
Post by pepmyster »
When you are in that range of anchors, both stand side by side. I've heard the Mantis has an edge on the Rocna. But that being said, both are great!
denpooch
Post by denpooch »
One main difference is that the Mantus anchor has about 50% of the anchor's weight at the tip. This will help initiate setting quicker than most others.
But check out this video SV Panope. The guy tests many popular anchors and has video footage of each anchor setting and and then resetting. At the end of the study he then sums up the pros and cons of each style. It's very informative and entertaining.
https://m.youtube.com/watch?v=l59f-OjWoq0
Interesting to say the least. Thanks for posting. Confirms my findings that a Mantus is really a great anchor with the best and quickest set of them all.
denpooch
Post by denpooch »
Yea Hans, we are both on the same page.
His main objection to the Mantus is the shank, which he believes is not thick enough and would have a propensity to bend. So I contacted Mantus and inquired about the
number of shank failures they have experienced and the number is WAY low. I dont recall the specifics but the failures were insignificant. In any event, they are guaranteed for life and they would send out a replacement shank.
My concern was the integrity of the bolts. I spoke to them about that and they have never had a bolt fail. They also suggested that most of their anchors are used as primary anchors and live on the bow fully assembled.
I would not worry the least about the bolts. The shank will bend and the anchor chain will break before you shear off those 4 bolts. ;-)
