50 amp power y spec
- zoomiej
- Vessel Info: 2001 Carver 466 MY
- Been thanked: 3 times
50 amp power y spec
Currently, I have a 50 amp (male) to two 50 amp y that allows to plug both 50 amp power cables coming from the boat into one connector ashore.
What I am looking to do is use one cord, with the y at the boat (female) end.
My question is this, what is the spec for the boat receivers, 50 amp 125v or 50 amp 125/240v
- buster53
- Been thanked: 262 times
Re: 50 amp power y spec
- Been thanked: 620 times
heres a pic that will help.
https://images.app.goo.gl/MjqUvLSGtLNTaR6a8
- Has thanked: 270 times
- Been thanked: 1159 times
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
I do need to budget my amps but not a big deal. I just turn off the air while using any other high draw appliances such as coffee makers, etc
- ColRon
- Has thanked: 77 times
- Been thanked: 153 times
“Escape Plan”
Murray, KY
really just depends on how much money you want to spend or how big of pain coiling the cord up is i guess. if you want to change imo . the single cord since you already have a y
g36 wrote:Source of the post imo a 50 ft 4 wire shore cord will start at about $400.00 in addtion to midnightsun suggestion of replacing a shore inlet. and for darrenlife's' suggestion,, it would be a pain in the butt for me to keep reminding my wife to turn stuff off and on to keep from tripping the circuit breaker. 50amp 125v are old but not obsolete in usa in the south where we boat, yes they are less options with it.
Not sure I am following you on this. Nothing to turn off as you have 100a of power available.
- ColRon
Midnightsun wrote:Source of the postg36 wrote:Source of the post imo a 50 ft 4 wire shore cord will start at about $400.00 in addtion to midnightsun suggestion of replacing a shore inlet. and for darrenlife's' suggestion,, it would be a pain in the butt for me to keep reminding my wife to turn stuff off and on to keep from tripping the circuit breaker. 50amp 125v are old but not obsolete in usa in the south where we boat, yes they are less options with it.
Hans, I think g36 was referring to darrinlife’s set up as he connects his 50 amp cord to a 30 amp adapter at the pedestal. At first I had the same thought as you until after I reread it a couple of times.
“Escape Plan”
Murray, KY
- Has thanked: 585 times
- Been thanked: 1231 times
zoomiej wrote:Source of the post I am currently away from my 396, but looking to come up with a solution for shore power.
What power is available from the one plug at the dock/shore pedestal..? This will affect what you can do properly.
