Refridgerator
- Petemait
- Vessel Info: 1983 Carver Riviera
- Has thanked: 56 times
- Been thanked: 18 times
Refridgerator
Anyone have a recommendation for a good 12 v fridge? The space for the fridge is about the size of a big mini fridge.
Thank you!
Pete
1983 Riviera 2807
Boston, MA
- throwback2
- Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys - Has thanked: 8 times
- Been thanked: 22 times
Re: Refridgerator
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 23 times
Re: Refridgerator
- Has thanked: 324 times
- Been thanked: 595 times
Re: Refridgerator
If you go for a dorm type, don't expect it to get below 40 degrees when the cabin temp hits 85 or more. Otherwise, it will be ok.
- Been thanked: 622 times
Re: Refridgerator
- Has thanked: 458 times
- Been thanked: 1699 times
Re: Refridgerator
If you go with a household unit and want it to work out on the lake, hook it up permanently to an inverter. This way, you can use it out on the water, and when on shore power, the charger will maintain the batteries while the unit is working. Or you can unplug and plug between the inverter and shore power but that's a pain. Setting up a switch to select one source or the other wouldn't be that difficult either. You can expect it to work more often than a marine/RV unit though so it's something to consider if you spend a lot of time on the water as it will drain your battery bank faster.
- Petemait
Re: Refridgerator
Thank you all again,
Pete
1983 Riviera 2807
Boston, MA
- Has thanked: 585 times
- Been thanked: 1231 times
Re: Refridgerator
Petemait wrote:Source of the post We recently bought a Carver Riviera and it does not have a fridge.
Thank you!
Pete
What is in there now ? Is the fridge just missing or is it one of those coolers in the space. It would be great if all the wiring for 110/12 is there.....Is there a breaker on the panel ?
Re: Refridgerator
Here is the one i used. Currently 10% off at WM. I bought it at WM when there were having a 25% off sale.
- Petemait
Re: Refridgerator
tomschauer wrote:Source of the post https://www.westmarine.com/buy/isotherm ... cordNum=10
Looks like they have a 20% off sale starting soon, i think i will get the isotherm you mentioned.
Was it easy to install?
Thanks,
1983 Riviera 2807
Boston, MA
