Genset battery switch
tonyiiiafl
Has thanked: 601 times
Been thanked: 190 times
Postby tonyiiiafl » September 26th, 2020, 4:02 pm
My 390CPMY has the battery shutoff switch mounted on the side of the sound cover on the genset. To me, it is a PITA to open the floor to turn on, run genset then do the same to turn off. I am thinking of relocating it on the side of the stairs where my inverter is mounted, ANyone else move their switch?
Been thanked: 622 times
Re: Genset battery switch
Postby g36 » September 26th, 2020, 7:01 pm
Are you talking about genset start battery? Why turn it off and on all the time? I've never turned mine off.
Been thanked: 243 times
Postby mjk1040 » September 26th, 2020, 8:18 pm
Only turn mine off in the off season and leave it on all boating season. But then again I see no problem in moving it if you want, cables will be the biggest expense in that project.
Has thanked: 458 times
Been thanked: 1699 times
Postby Viper » September 26th, 2020, 8:48 pm
Ya the only time you really need to shut it off is for the winter if you don't want to disconnect the batteries or to service the circuit. Instead of relocating the switch to a conspicuous spot like that, you can use one of these; remotely activated with a rocker switch at the helm or any convenient place you want...
https://www.bluesea.com/products/category/13/60/Remote_Battery_Switches/ML-Remote_Battery_Switches
Has thanked: 324 times
Been thanked: 595 times
Postby tomschauer » September 26th, 2020, 10:00 pm
Same here. Only turn mine off when the boat is on land.
Has thanked: 270 times
Been thanked: 1160 times
Postby Midnightsun » September 27th, 2020, 7:15 am
I'll echo everyone else, in fact all my battery switches remain on until haul out.
