Gas Grill
- HudsonRiver01
- Vessel Info: 1990 Carver Santego 38
- Has thanked: 14 times
Gas Grill
OK, so stupid question. I just purchased a propane grill (Kuuma). Instead of using the small screw on tanks, can I just purchase a propane grill set up with regulator from Home Depot and use that? I should know this but..
Re: Gas Grill
It will work fine however you will need to purchase the adapter hose to connect the home depot bottle to the regulator of the Kuuma grill which has threads for a small 1 lb bottle. Like this. https://www.canadiantire.ca/en/pdp/mast ... 1097p.html
I used to use a small 5lb bottle and did the same you want to do with the hose shown above, still have it but went back to the 1lb bottles.
Re: Gas Grill
I would get the hose Hans mentioned above, you want to use the regulator that came with the grill, that way you know it's the right spec for that unit.HudsonRiver01 wrote:QR_BBPOST ...can I just purchase a propane grill set up with regulator....
- HudsonRiver01
Re: Gas Grill
Midnightsun wrote:QR_BBPOST It will work fine however you will need to purchase the adapter hose to connect the home depot bottle to the regulator of the Kuuma grill which has threads for a small 1 lb bottle. Like this. https://www.canadiantire.ca/en/pdp/mast ... 1097p.html
Thank you both for the advice. Steaks will be ready soonViper wrote:
QR_BBPOSTI would get the hose Hans mentioned above, you want to use the regulator that came with the grill, that way you know it's the right spec for that unit.HudsonRiver01 wrote:QR_BBPOST ...can I just purchase a propane grill set up with regulator....
