Breaker Panel
- jonest7
- Vessel Info: 1986 Mariner 32
Breaker Panel
I have been told that there may be another panel other than the main panel in the cabin.
Appreciate any help
- Has thanked: 270 times
- Been thanked: 1159 times
Re: Breaker Panel
https://www.amazon.ca/ZOOKOTO-Circuit-Breaker-Automotive-Waterproof/dp/B07GCVSBNP
- Has thanked: 585 times
- Been thanked: 1231 times
Re: Breaker Panel
Re: Breaker Panel
Re: Breaker Panel
Sorry not much help...the hunt is on...
- Has thanked: 324 times
- Been thanked: 595 times
Re: Breaker Panel
- jonest7
Re: Breaker Panel
Re: Breaker Panel
- Has thanked: 72 times
- Been thanked: 1054 times
Re: Breaker Panel
Check to see if you have any voltage on the big solenoids by the winch. If you do, then start troubleshooting the switch circuit(s) to see where they are fed from.
- Phrancus
- Has thanked: 16 times
- Been thanked: 133 times
- Contact:
Re: Breaker Panel
it works as an off/on switch but doubt that it will do much quick enough before it burns when stuck. Replaced the solenoids for a modern single block with remotes, as the foot switches were toast too.
