A couple of questions
- Jmac
- Vessel Info: 2007 Carver 36 SS
Twin Volvo Penta 8.1 GXii-g
7.3 KW Kohler - Location: East TN
- Has thanked: 20 times
Does anyone know what the three holes are used for at the back edge of the swim deck (circled in red) ?
(Hopefully the picture is attached).
Also, how or does the shade/screen unlatch from the forward hatch? Mine will not unlatch. The surveyor noted this as a safety concern in case of an emergency egress. (Hopefully a picture is attached for this too).
Thanks in advance for replying.
2007 36 SS
2007 36 SS
JMac
2007 Carver 36 SS
7.3 KW Kohler
Tellico Lake, Loudon, TN
2007 Carver 36 SS
7.3 KW Kohler
Re: A couple of questions
No pics yet.......see the add files button just above where it says post reply.......you can preview to check before post as well......
- Jmac
Swim deck
JMac
2007 Carver 36 SS
7.3 KW Kohler
2007 Carver 36 SS
7.3 KW Kohler
- Jmac
Hatch screen
JMac
2007 Carver 36 SS
7.3 KW Kohler
2007 Carver 36 SS
7.3 KW Kohler
- Been thanked: 654 times
Sorry don't see pics
- Jmac
Not sure why 2 pics will not upload.
I'm selecting "add files" and then select the 2 pics I'm trying to upload but I get a yellow triangle ⚠️ symbol each time
JMac
2007 Carver 36 SS
7.3 KW Kohler
2007 Carver 36 SS
7.3 KW Kohler
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 149 times
Maybe pics do not meet upload requirements (e.g. file size too large, format not supported, etc.) and that's what the yellow triangle is indicating?
MV Verity
2002 Carver 396
2002 Carver 396
- Jmac
Trying again
JMac
2007 Carver 36 SS
7.3 KW Kohler
2007 Carver 36 SS
7.3 KW Kohler
The shade and screen should separate from each other. Usually it's a magnetic strip along the screen's end and a magnetic strip on the shade's end where the shade and screen meet but different brands might use a different means to latch one to the other when one is moved. You should be able to pull them apart.
The three holes in the platform are scuppers. They could be drains for the lockers in the transom, and if there is a hatch in the platform, that might drain out there as well. The rubber flaps act as check valves that allow water to drain out from a space while preventing water from getting in.
- Jmac
Thank you Viper for the explanations.
The scuppers makes perfect sense to me now. I was thinking they were places to possibly install a David of sorts.
As far as the screen/shade, I cannot get them to separate. Even the surveyor tried to no avail. I will try to see if there's a part number, brand name, or some other identifier to research how to get them to separate.
Many thanks!
Many thanks!
JMac
2007 Carver 36 SS
7.3 KW Kohler
2007 Carver 36 SS
7.3 KW Kohler
