New boat to me, is this an automatic generator transfer switch?
ron54
Vessel Info: 2006 Crownline 262ex
1985 Carver Mariner 3697
Has thanked: 12 times
Been thanked: 4 times
Post by ron54 »
If so, does this protect the genset if I forget to disconnect shore power? 85 Carver 3697, 7 yr old Kohler 7.5 ekd genset. Thanks
Been thanked: 285 times
Re: New boat to me, is this an automatic generator transfer switch?
Post by buster53 »
Been a while since I looked at mine, but pretty sure it is an auto transfer switch and if working properly, you can turn on your genset while still hooked to shore power. When you start up the genset, you will hear the switch “chatter” while making the switch over.
Put it this way, if you don’t have a manual switch on your panel, you have to have an auto switch.
Been thanked: 492 times
Post by waybomb »
Yes. Automatic Transfer switch.
ron54
Post by ron54 »
Thanks very much for the replies! I thought it had one but just discovered this under a hatch under the dinette seat. No labels anywhere on it.
ron54
Post by ron54 »
Actually there is one label but only a number. Anyone have an idea on make, model, etc.? Always like to have a manual on stuff. Internet search unsuccessful so far.
Yes, that is the auto transfer switch and something you should remember if you ever have a problem getting shore power to the main panel. Sometimes those relay contacts get burned and you'll get power from the generator (when it's running) but not from shore power when you're plugged in. There are a few other threads on here that list sources for those relays that can be replaced. In a pinch you can clean the contacts to get shore power working again (but observing all the precautions about working on line-powered equipment!).
