Hello,
My carver cruiser is filthy green moss and slime and just generally needs a good clean. I am london based any ideasa on what to use to clean her?
Help
- nina
- Vessel Info: carver cruiser 1983
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Help
A small, electric power washer will take care of that. Been using mine for close to 10 years. Have even loaned it out to dock neighbors who liked using it so much, they bought their own.
- nina
Re: Help
Just regular toilet bowl cleaner does some really good work, especially on all the fiberglass areas. Will remove any old waxes, plus any kind of mold or mildew. Scrub it down lightly with that, then use the powerwasher to thoroughly remove everything and rinse it down. A little buffing and some wax and it will look like brand new.
You can even use that on a lot of the vinyl, but you don't want it to sit for a long time and you do need to rinse well so there's no long-term damage to the threads.
BUT you also have to careful on colored paint or vinyl or especially any fabrics because it would bleach the color too. If you can remove all that stuff and just concentrate on the white surfaces first, it will be a lot easier.
- buster53
Re: Help
You’d be surprised what the power washer will do without any cleaners.nina wrote:Thank you buster53, would you suggest a cleaning fluid?
