port engine not starting
Rayjs148
Has thanked: 18 times
Postby Rayjs148 » August 14th, 2024, 9:27 pm
Hello, I have a Carver Santego 31 with twin 350 Crusader XL motors. The port engine stalled on our way back to marina and will not start. Engine turns over fine and can hear fuel pump running.
Observations: noticed when first turning ignition key the tachometer jumps up an down and the Engine Sync gauge will jump over to port side. Spark seen from ignition coil to dist cap, not always seeing a spark from dist cap to plugs.
replaced start relay, ignition coil ,dist cap, rotor and get the same results.any thoughts, thanks
Has thanked: 53 times
Been thanked: 425 times
Re: port engine not starting
Postby waybomb » August 14th, 2024, 9:36 pm
Are you sure fuel is getting to the cylinders? Verify.
Rayjs148
Postby Rayjs148 » August 15th, 2024, 4:25 pm
Thanks for the reply, my observations suggest problem is ignition related as we do not see a spark from Dist cap to plugs but do see a spark form ignition coil to dist cap, just not sure where to go from there.
Has thanked: 575 times
Been thanked: 1202 times
Postby bud37 » August 15th, 2024, 9:30 pm
Rayjs148 wrote:Source of the post Thanks for the reply, my observations suggest problem is ignition related as we do not see a spark from Dist cap to plugs but do see a spark form ignition coil to dist cap, just not sure where to go from there.
What year is your boat ? Is it points or does it have a module in the distributor ??
Rayjs148
Postby Rayjs148 » August 18th, 2024, 8:43 pm
Problem resolved. It was the ignition relay located down side of engine.thanks for all the replies.
