Replace AC Circuit Breaker Panel?
cjblovinlife
Vessel Info: 1996 Santego 380
Has thanked: 27 times
Been thanked: 8 times
Post by cjblovinlife »
I have a 1996 380 Santego . Some of the breakers on the AC panel are failing. I do not use a generator at all so I have no need for the shore power and generated power switches. I’m thinking about replacing the whole panel. Has anybody done this? Does anybody have any recommendations I see blue sea systems has a few options
Re: Replace AC Circuit Breaker Panel?
Try a boat salvage yard, they usually have all kinds of panels.
http://www.themarineconnection.com/
Also try Don's Marine Salvage in Clearwater FL
Post by g36 »
My carver has some unused circuits oem from carver. Are you talking about the ship/shore selector cause you mentioned you dont use a generator,,is it not installed,? Or the individual branch breaker? The unused ones for me the breaker/switch is already installed. If you have any unused ones and can match the amps it would be way easier to rewire and relabel than your plan to totally replace the entire panel. I've had to do this and I've also replaced a couple that I couldn't use another for.
Been thanked: 492 times
Post by waybomb »
You're going to sell the boat someday.
Fix it stock.
A jury rigged boat will lose a bunch of money
I agree with Fred above.....that would be my first inclination however it works out.
pondiscio@gmail.com
Vessel Info: Carver 430 1995 "Wonder More"
Has thanked: 3 times
Been thanked: 11 times
Post by pondiscio@gmail.com »
You can get most... of if not all the breakers and switches from blue sea systems or digikey. Its not too tough a job. you will want to replace the lugs on the ends of the heavy gauge wires too.
cjblovinlife
Thanks everyone for the input. The ones I am having issues with are just branch circuits I did find some on salvage site thank you .
