1977 Carver 2276 - items
sdsurf
Vessel Info: 1977 Carver 2276
Has thanked: 3 times
Postby sdsurf » January 26th, 2025, 9:37 am
Good Morning
I have a 1977 Carver 2276 in great condition but missing a few items. It has two sinks, one in the Galley and one in the head. I am missing both water tanks for those. Any idea of what they would be or are spec'd? If not original, what would work...
I also notice two optional seats on either side of the motor. Same question, what was there originally (spec'd) or what might work now? They would need to be mounted tot he transom or somehow removable for storage/access below in the deck
Mike
Been thanked: 616 times
Re: 1977 Carver 2276 - items
Postby g36 » January 26th, 2025, 10:55 am
Have you spent some time googling your boat and looking at other images and info?. I know there were some manuals/brochures online too that may help
Postby g36 » January 26th, 2025, 11:10 am
I found this online that will probably help....https://manualzz.com/doc/53460136/carve ... er-s-guide
Been thanked: 394 times
Postby Cooler » January 26th, 2025, 1:04 pm
I doubt there would have been separate tanks for each sink. Generally there is one tank serving either or both. Once you locate where that tank was located, you can measure to accommodate installation and angle to install. It is probably something in the 15 to 22 gallon range. Might be a good idea to find out why the original tank was removed. If failure caused by freezing, then the lines may need an inspection for leaks. Good luck! 8-) er
Users browsing this forum: Google [Bot] and 39 guests
