79 Monterey gm350 questions
Thomask702
Vessel Info: 1979 Carver Monterey - 25'
- Volvo Penta 280
- GM 5.7l (350) SN 3970010
Has thanked: 3 times
Post by Thomask702 »
Having trouble finding out if my engine is a 2 bolt or 4 bolt main, and was wondering if someone with a similar vessel could help with that.
Also, I'm fairly certain she needs a new oil pan and am not sure if I should get a standard or an aluminum model. She seems to be sucking bilge water (leak fixed) into the oil and leaking oil into the bilge. I was told it was a freeze plug but that didn't make sense to me.
Can I spin the engine around without removing the drive shaft? Or is it just much work to do it either way? Anything else I should do while I'm down there?
Any and all help and advice is greatly appreciated.
Best
-Thomas
- Volvo Penta 280
Elochoman Slough Marina
Re: 79 Monterey gm350 questions
Looks like she's a sterndrive application. The boat has to come out of the water, drive has to be removed, then you can remove the engine to get to the pan.
