RPM Guages flux
Topic author
urbie
Vessel Info: 1989 34' Santego
RPM Guages flux
Postby urbie » September 16th, 2014, 12:31 am
Both rpm guages on my 1989 34' Santego fluxuate all over the place. Do I need to replace the guages or could there be another problem?
eric_b
Vessel Info: 1986 Carver 3227 Convertible
Re: RPM Guages flux
Postby eric_b » September 16th, 2014, 9:56 am
There are usually dials in the back of the gauges which determine thenumber of cylinders that are being monitored. Moving those dials back and forth removes the corrosion on the contactors, which usually resolves this issue. It is a common issue and I have had to do this with the gauges on my '86 32' Convertible.
Topic author
urbie
Re: RPM Guages flux
Postby urbie » September 16th, 2014, 8:03 pm
Thanks I'll give it a try
Users browsing this forum: No registered users and 111 guests
