Carver 356 RPM issues
- cpoint
- Has thanked: 208 times
- Been thanked: 26 times
Re: Carver 356 RPM issues
- Been thanked: 615 times
- Has thanked: 579 times
- Been thanked: 1210 times
- Been thanked: 1043 times
In any case, tachs themselves are pretty inexpensive, so finding ones that look good (or that match what you want to upgrade the other to) might be the hardest part.
g36 wrote:Source of the post Smartcraft is a mercruiser engines product.
I thought he did have Mercruisers in the boat?
However, checking the Smartcraft sites, it seems like his 2000 is just a tad too old to have it:
"The SmartCraft line of products are applicable to all Mercury/Mariner OptiMax outboard engines starting with Model 2000, and all MerCruiser 8.1 liter engines for Model Year 2001."
- Has thanked: 324 times
- Been thanked: 595 times
- cpoint
Close to the same as mine, but mine are blue water horizons (freshwater cooled). I would replace the tachs until you get the engines running correctly.
I would definitely verify the fuel pressure is correct. These have a mercury "cool fuel" set up with the fuel pump and regulator in a box under the engine that is water cooled. The regulators fail more often than the pumps. They sometimes fail to high pressure, making you engines run very rich (smell like gas) this will also damage the injectors.
There is a very fine fuel filter in the cool fuel box. It could be that simple!!!!
- cpoint
tomschauer wrote:Source of the post Hey, I almost forgot...
tom, do you mean this tiny filter? if so that did have some stuff in it. he thought he would clean and hope also, but did not help.
Users browsing this forum: No registered users and 129 guests
