Genny Died
- Been thanked: 1312 times
Re: Genny Died
Good stuff....how come no pics of the offending fence posts....
- CaptBob
- Vessel Info: Shopping....
- Been thanked: 33 times
Re: Genny Died
Capt Bob!
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat....
Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
- Keith S
- Vessel Info: 2005 38 Super Sport
- Been thanked: 21 times
Re: Genny Died
Capt Bob
I noticed in your photo that you have a ground cable issue. The yellow DC negative cable should be located on the stud just above and to the left of where it is now. Yours is on the equipment ground stud which in boat speak would be where the green bonding wire should go. It is a very common installation error even from boat manufacturers. Besides the opportunity for corrosion while sitting in the drip pan, it also is now using the braided strap that was not meant to normally carry current to conduct starter cranking current. The clue is the label in plain English that says negative cable here.
- CaptBob
Re: Genny Died
Wow, that's quite a catch. I had a hard time finding it on the pic and you told me what to look for. I'll check it out next time im on the boat. Pretty positive that was a factory install, I know I haven't messed with that, and what I know of the previous owners, I doubt they did either.
Capt Bob!
