Is there really a difference between anchors?
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Is there really a difference between anchors?
Anyone know how the Mantus fits on the Carver bow roller on the Mariner ?
- Has thanked: 268 times
- Been thanked: 1153 times
- pepmyster
8.1 Volvo Penta
- Has thanked: 474 times
- Been thanked: 201 times
- denpooch
- Has thanked: 85 times
- Been thanked: 86 times
As far as fit on a mariner. On the Mantus website you can print out a template and mount it on foam board, which helped me decide on the size I chose. The anchor works well with the bow roller, however, I added the optional 'anchormate' which holds the anchor firmly in place when at home. I did have to make one modification to use the mate. I needed to add a longer bolt to go through the roller and the bolt had to move freely within a stainless steel tube, which allowed me to fully tighten the mate while allowing the roller to move easily.
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
Midnightsun wrote:Source of the post The Mantus does not fit my bow roller well at all, tried a 35lb last year and even that did not work. Would need to change the bow roller setup which will eventually happen if I can manage to depart with my 50lb bling bling wonder.
How close the the nose did the point of the anchor come? I’m worried about them bumping when stowed.
denpooch wrote:Source of the post Hey Bud. I think a plow and spade function a little differently, The spade may do a better job at burying itself as a 'new generation' design, but I may be wrong about that.
What size anchor did you go with?
- denpooch
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 467 times
- amanphoto
There are a lot of anchors that look the same. It all depends on bottom structure and conditions.
- amanphoto
RGrew176 wrote:Source of the post I have a Delta Plow on my Carver. It has been a great anchor so far. Have pretty much used Danforth styled anchors before. While I had no issues with that style too I think the plow is a better anchor. Mine has not failed to grab yet on the first try. Are other styles better? Perhaps but I am very satisfied with my plow.
I’m not saying that plows don’t work. If they didn’t, they wouldn’t be on so many boats. If I’m going to replace my anchor, I’m going to replace it with something that works better.
Currently I have a 22 lb plow style with 120’ of chain. Hit holds. But I don’t trust it. It’s undersized for the size of the boat (Mariner 350).
As a side note, My previous boat (25’ Monterey) had a 13 lb fortress style anchor on it. It was able to hold that boat and a 40’ Sulverton with minimum drag during a raft up. That anchor was a little finicky to set and always came up dirty. The plow anchor always comes up clean.
Users browsing this forum: No registered users and 91 guests
