Marine Air Systems 'HHH' error code
- Been thanked: 654 times
Re: Marine Air Systems 'HHH' error code
Curious what it would do if you ran it in heat mode instead of cooling mode? Works fine? Or errors out?
darrenlife
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
Thanks to everyone for your advice. We are out for our annual two week cruise and will let you know the outcome soon. Fortunately the weather hasn’t demanded the AC very often, we’ve been at anchor most of the time with a nice breeze.
Wow that's odd, it's been killer hot up my way. Not complaining though, I'll take it for as long as we can get it. Have a great trip.
darrenlife
The unit will run fine for about 10 minutes and then shut down followed by the HHH code
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Darren, I am late to the game on this post. The HHH code as mentioned earlier is a lack of water flow. You can try running compressed air through the system from the through hull fitting. I am assuming you have opened and cleaned your strainer at the thru-hull fitting?
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
darrenlife
Yes, strainer is clean and forced ‘garden hose pressure’ through the system. I think I may try pulling the unit in the spring and bring to a service depot to be inspected.
I’ll provide an update
