battery and windlass
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 23 times
Thanks.
- Has thanked: 585 times
- Been thanked: 1231 times
Re: battery and windlass
If you check the batteries separately with a voltmeter as the windlass is operated ( you will see a volt drop ) you should find the battery it is wired to in my opinion. Also check all your battery connections for corrosion and loose connectors etc.
- tgebler
- Has thanked: 324 times
- Been thanked: 595 times
May want to check there first.
- tgebler
tgebler wrote:Source of the post So..... I checked the batteries, all better than 12v and checked all the connections and no problems there. Is it possible I need a new windlass motor? Any other suggestions would be appreciated. Thanks.
When you say better than 12volts....how much....because a fully charged battery should be around 12.7 volts after the surface charge is gone.
- tgebler
- tgebler
- tgebler
