1998 405
Uk4life
Vessel Info: 1998 405 Aft Cabin
Has thanked: 4 times
1998 405
Post by Uk4life »
I made it through Ian almost unscathed!! I do need to replace the panels that go around the back deck. Anyone done this before and have suggestions on what to use? Any recommendations in the Punta Gorda area? Seems like an easy enough job just need a place to make them then I will install. Starboard side is in good enough shape to be used as a template and measures the same as the port side. The other panels are a rectangle and square....
Re: 1998 405
Post by g36 »
First off , hello fellow 405 owner. I'm glad you are ok and the boat seems to be in good shape. I couldn't imagine what you've been through and I'm praying for you guys. We love those areas of the coast. Heres a link to some discussions on this forum about the sundeck panels. You may also try the search on here for other panel options. You won't find these from carver of course but you may get them made as in this post ...viewtopic.php?f=7&t=2026&p=14596&hilit=Panels+sundeck#p14596
Been thanked: 1114 times
Re: 1998 405
Glad you made it though pretty much OK!!
Looks like your corner pieces are still there, which I think will make this a MUCH easier project!!
Uk4life
Re: 1998 405
Post by Uk4life »
We love love love our 405! Appreciate the link to the other post, I am not very good at searching!
MyPleasure
Has thanked: 2 times
Been thanked: 23 times
Re: 1998 405
Post by MyPleasure »
Hi, I looked into this before, and I found this product called Puck Board. It comes in sheet sizes 4’ x 8’ or 5’ x 10’. It’s made of high density polyethylene and comes in a 1/4” thickness.
I don’t know if it’s what you are looking for, but it might work for you.
Al
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
Uk4life
Re: 1998 405
Post by Uk4life »
I just searched Puck Board but the largest size I could see is 4 x 8. Do you know where to get it in 5 x 10? The 2 side panels are 105" long
I appreciate the info
Phrancus
Has thanked: 16 times
Been thanked: 136 times
Re: 1998 405
Post by Phrancus »
considered switching to transparent? Clear or tinted, lots of materials in that area.
