1998 405
- Uk4life
- Vessel Info: 1998 405 Aft Cabin
- Has thanked: 4 times
1998 405
I made it through Ian almost unscathed!! I do need to replace the panels that go around the back deck. Anyone done this before and have suggestions on what to use? Any recommendations in the Punta Gorda area? Seems like an easy enough job just need a place to make them then I will install. Starboard side is in good enough shape to be used as a template and measures the same as the port side. The other panels are a rectangle and square....
- Been thanked: 654 times
Re: 1998 405
First off , hello fellow 405 owner. I'm glad you are ok and the boat seems to be in good shape. I couldn't imagine what you've been through and I'm praying for you guys. We love those areas of the coast. Heres a link to some discussions on this forum about the sundeck panels. You may also try the search on here for other panel options. You won't find these from carver of course but you may get them made as in this post ...viewtopic.php?f=7&t=2026&p=14596&hilit=Panels+sundeck#p14596
Re: 1998 405
Glad you made it though pretty much OK!!
Looks like your corner pieces are still there, which I think will make this a MUCH easier project!!
- Uk4life
Re: 1998 405
We love love love our 405! Appreciate the link to the other post, I am not very good at searching!
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 23 times
Re: 1998 405
Hi, I looked into this before, and I found this product called Puck Board. It comes in sheet sizes 4’ x 8’ or 5’ x 10’. It’s made of high density polyethylene and comes in a 1/4” thickness.
I don’t know if it’s what you are looking for, but it might work for you.
Al
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
- Uk4life
Re: 1998 405
I just searched Puck Board but the largest size I could see is 4 x 8. Do you know where to get it in 5 x 10? The 2 side panels are 105" long
I appreciate the info
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Re: 1998 405
considered switching to transparent? Clear or tinted, lots of materials in that area.
